Specs
Engine Type Four-stroke, liquid-cooled, DOHC, parallel twin
Displacement 249 cc
Bore & Stroke 62.0 x 41.2mm
Maximum Torque 22 Nm (2.24 kgf/m) 16.2 lb-ft/9,500 rpm (33,5 cv)
Compression Ratio 11.6:1
Carburetor Keihin CVK30 x 2
Ignition Digital
Transmission 6-Speed
Final Drive O-Ring Chain
Cooling Liquid
Frame Semi-double cradle, high-tensile steel
Rake/Trail 26 degrees / 3.2 in.
Front Tire Size 110/70-17
Rear Tire Size 130/70-17
Wheelbase 55.1 in.
Front Suspension / wheel travel 37mm hydraulic telescopic fork / 4.7 in.
Rear Suspension / wheel travel Bottom-Link Uni-Trak® with 5-way adjustable preload / 5.1 in.
Front Brake Type Single 290mm hydraulic disc with two-piston caliper
Rear Brake Single 220mm petal disc with two-piston caliper
Fuel Tank Capacity 4.8 gal.
Seat Height 30.5 in.
Dry Weight 333 lbs. / 337 lbs. (CA-model)
Overall length 82.1 in.
Overall width 28.1 in.
Overall height 43.7 in.
Color Lime Green, Ebony, Passion Red, Candy Plasma Blue
